DA 50 med pittsdämpare, tändsystem finns, men isoleringen på kabel till tändhatten är skadad så kan behövas bytas ut.
Pris 2900
Specifications
Displacement: 3.05 ci (50 cc)
Weight: 2.94 lbs (1.33 kilos)
Weight w/Standoffs: 3.13 lbs (1.42 kilos)
Bore: 1.6771 in (42.6 mm)
Stroke: 1.3779 in (35 mm)
Length: 6.7 in (170 mm)
Warranty: Three year
Bolt Circle: 30mm
Prop Bolt: (4) 5mm
Features
Desert Aircraft, auto advance, electronic ignition.
Walbro Carburator
Exclusive Desert Aircraft designed cylinders, pistons, and crankshaft.
CNC milled, 7075 aluminum alloy crankcase.
Low vibration.
Long rod to stroke ratio.
Aerobatic power curve.
Recommended Props
2-Blades
23x8
22x10
22x8
3-Blades
22x10n
20x12
20x10
