LiPo Laddare / Balanserare / Urladdare / Hobbyking™ T682 AC 6s 10A 90W Eco Touch
I mycket fint skick, väldigt lite använd och fungerar perfekt.
Laddaren har en bakgrundsbelyst touchdisplay, och har både AC & DC ström.
Mer Info:
Hobbyking™ T682 AC 6s 10A 90W Eco Touch Balance Charger/Discharger
Charge at home on 110/240v or in the field on 12v. The Hobbyking™ Eco Touch handles both!
The
Eco Touch is a rock solid yet beautifully refined charger that's able
to charge, balance and discharge Lion, LiPo, LiFe, NiCd and NiMH
batteries. Its 3 inch LCD touch screen nicely displays all the
information you would ever want to know when charging your packs with a
graph showing the voltage increase/decrease, battery cell graphic
showing the level of charge plus the individual cell voltage and it's
back lit!
Features;
• AC 100~240v or 12V DC input
• Microprocessor controlled
• Delta-peak sensitivity
• Individual cell balancing
• Li-ion, LiPo and LiFe capable
• Ni-Cd and NiMH capable
• Large range of charge currents
• Store function, allows safe storage current
• Input voltage monitoring. (Protects car batteries at the field)
• Battery break in and cycling.
Spec.
Input Voltage: 11~18v
Circuit power: Max Charge: 90W / Max Discharge: 10W
Charge Current Range: .1~10.0A
Discharge current range: .1~2.0A
Discharge current range (LiPo, LiFe/Li-ion): 2.0- 4.2v/cell
Ni-MH/NiCd cells: 1~16
Li-ion/Poly cells: 1~6
Pb battery voltage: 2~20v
Weight: 520g
Dimensions: 146x148x58mm
This charger has a T connector charge plug, balance board and 12v adapter.
Pris: 399kr
Mer Info:
The
back lit!
Features;
Spec.
Weight: 520g
Pris: 399kr
